Refer to the drawing of a water storage tank with a differential pressure (D/P) level detection system. Tank water level indication will be lower than actual level when reference leg temperature is ___
Water Storage Tank-PG-51
Tank water level indication will be lower than actual level when reference leg temperature is __________ than calibration conditions; or when there is a break in the __________ leg of the D/P detector.
A. less; reference
B. less; variable
C. greater; reference
D. greater; variable
