The distribution transformers are designed to keep the ___
The distribution transformers are designed to keep the iron-losses minimum because
A. the primary of distribution transformer is energized for all the twenty-four hours
B. iron losses may damage the insulation
C. iron-losses will heat up the coil
D. none of the above
