The excessive voltage drop will cause excessive ___ buildup
Power, lost as wattage along the length of the circuit conductors, is dissipated as heat.
The excessive voltage drop will cause excessive heat buildup.
Not corrected (by increasing the conductor wire size to lower the conductor resistance), the heat buildup can lead to conductor insulation failure, which will cause even more critical circuit problems.
A) True
B) False
Answer:A
