A main generator is about to be connected to an infinite power grid.
Generator voltage is slightly higher than grid voltage and the synchroscope is rotating slowly in the clockwise direction.
The generator breaker is closed just as the synchroscope pointer reaches the 3 o’clock position.
Which one of the following is most likely to occur after the breaker is closed?
A. The breaker will remain closed and the generator will supply only MW to the grid.
B. The breaker will remain closed and the generator will supply both MW and MVAR to the grid.
C. The breaker will open due to overcurrent.
D. The breaker will open due to reverse power.
