The normal forward or reverse direction of rotation for the input shaft of the driven equipment, due to either the method of coupling or to the type of speed reduction equipment employed, may not be the same as for the electric motor ___
The normal forward or reverse direction of rotation for the input shaft of the driven equipment, due to either the method of coupling or to the type of speed reduction equipment employed, may not be the same as for the electric motor.
If the forward rotation of the motor is the opposite of that required for forward rotation of the driven equipment, the motor circuitry must be changed (electrically reversed) to effect the required rotation on command (start/run) of the motor before the drive train is permanently coupled.
A) True
B) False
Answer:A
