The one-time reversing of the motor’s direction of rotation can be accomplished by the manual interchange of lines T1 and T3 on either the line or load side of a single-direction 3-phase (3-pole) motor -starter (usually the load side) ___
The one-time reversing of the motor’s direction of rotation can be accomplished by the manual interchange of lines T1 and T3 on either the line or load side of a single-direction 3-phase (3-pole) motor -starter (usually the load side).
When repeated reversal of the driven equipment’s direction of rotation is required for the processing of the material, the control circuit must be modified to effect the reversal of the motor’s direction of rotation by interchanging the motor leads on a cyclic (or repeatable) basis.
A) True
B) False
Answer:A
