The output voltage of an inverter can be controlled by ___
Assertion (A): The output voltage of an inverter can be controlled by PWM technique
Reason (R): In a current source inverter the input current is constant.
A. Both A and R are correct and R is correct explanation of A
B. Both A and R correct but R is not correct explanation of A
C. A is correct but R is wrong
D. A is wrong but R is correct
