The reason why a slight difference between the input bias current occurs in op-amps is due to the unsymmetrical circuit component parameters ___
The reason why a slight difference between the input bias current occurs in op-amps is due to the unsymmetrical circuit component parameters.
This unsymmetrical condition also produces a difference in input voltage called what?
A. drift voltage
B. differential voltage
C. input offset voltage
D. input threshold voltage
