The rotor slots in an induction motor are, usually not kept parallel to the shaft as it
A. helps the rotor teeth to remain under the stator teeth.
B. helps in reducing the tendency of the rotor teeth to remain under the stator teeth.
C. improves pf.
D. improves efficiency.
