The secondary control circuit of the separately derived system cannot be referenced to the equipment-grounding system, unless the electrical-power distribution system within the building or other structure is referenced to the equipment-grounding system…
If the electrical-power distribution system is a 3-phase AC, 3-wire floating delta, a separately derived control-voltage source cannot be grounded.
A) True
B) False
Answer:B
