To adjust the current setting of the Overcurrent Relay, it must be adjusted at ___
To adjust the current setting of the Overcurrent Relay, it must be adjusted at the Plug Setting which is available in 7 Tap, ie 50%, 75%, 100%, 125%, 150%, 175%, 200%.
Which will be current rate of 1000/5 A CT.
If Plug Setting is 150%, CT will deliver
A. 5.0 A
B. 6.25 A
C. 7.5 A
D. 8.75 A
