To prevent ___ buildup, especially in the rotating member, fins are normally mounted on the ends of the rotor
When the AC induction motor is operating under full-load current conditions, the current flowing against the wire resistance of the motor windings and the eddy currents that flow in the steel structure of the stator and rotor assemblies generate ___________ in both the stator and rotor windings.
To prevent ___________ buildup, especially in the rotating member, fins are normally mounted on the ends of the rotor to force some air movement through the motor.
A) heat; heat
B) power; heat
C) heat; current
D) voltage; voltage
Answer:A
