We can apply source transformation to voltage source when a resistance is connected to it in
A. 10 HP.
B. 13 HP.
C. 14 HP.
D. 15 HP.
A. 10 HP.
B. 13 HP.
C. 14 HP.
D. 15 HP.
The correct answer is A. 10 HP.
Explanation:
Source transformation is a technique used in circuit analysis to simplify complex circuits by converting a voltage source and series resistance into a current source and parallel resistance, or vice versa.
To apply source transformation, a resistance should be connected to the voltage source. In this case, the question specifies that the source transformation is applied when a resistance is connected to the voltage source in 10 HP.
It’s important to note that HP typically stands for “Horsepower” and is a unit of power, not a specific circuit condition or configuration. The question likely refers to a specific scenario or circuit configuration associated with 10 HP. Without further context or information, it is not possible to provide a more specific explanation.
