What are the working conditions of Directional Overcurrent Relay?
A. When the current at the relay is visible Greater than or equal to the adjusted current value Relay will work
B. When the current at the relay is visible Greater than or equal to the adjusted current value and have the right direction Relay will work
C. When the current of the relay is visible Greater than or equal to the adjusted current value and have the opposite direction Relay will work
D. When the current at the relay is visible Less than or equal to the adjusted current value and have the right direction Relay will work
