What generally happens when thermowell mass increases?
A. Faster response
B. Slower response
C. Higher voltage
D. Lower resistance
Explanation:
As thermowell mass increases, the thermowell requires more time to absorb and transfer heat from the process to the temperature sensor. As a result, the RTD or thermocouple responds more slowly to temperature changes.
Why This Happens
A larger thermowell has:
  • Greater thermal mass
  • More material to heat up or cool down
  • Increased thermal inertia
This causes a delay before the sensor reaches the actual process temperature.
Effects of High Thermowell Mass
:white_check_mark: Better mechanical strength
:white_check_mark: Improved resistance to vibration and flow forces
:cross_mark: Slower temperature response
:cross_mark: Increased measurement lag
Effects of Low Thermowell Mass
:white_check_mark: Faster response time
:white_check_mark: Quicker detection of temperature changes
:cross_mark: May have lower mechanical strength
Faster response
  • Opposite of what occurs with increased mass.
Higher voltage
  • Thermowell mass has no effect on voltage generation.
Lower resistance
  • Thermowell mass does not affect RTD resistance directly.
Because increased thermowell mass increases thermal inertia and delays heat transfer to the sensor, Option B (Slower response) is the correct answer. :white_check_mark:
