What type of control action anticipates disturbance before it affects?
What type of control action anticipates disturbance before it affects PV in advanced loop strategies?
A. Feedback
B. Cascade
C. Feedforward
D. Ratio
Correct Answer: C. Feedforward
:brain: Explanation (Advanced Control Strategy)
In feedforward control, the system measures disturbances before they impact the process and takes corrective action in advance.
  • Instead of waiting for PV to deviate, it acts based on a measured disturbance variable
  • This makes the control action proactive, not reactive
:gear: How it works
  1. A disturbance (e.g., load change, inlet flow variation) is measured directly
  2. The controller calculates the required correction
  3. The output is adjusted before PV changes
:backhand_index_pointing_right: Example:
If inlet flow suddenly increases, feedforward immediately adjusts the control valve before temperature or pressure deviates
:repeat_button: Why Feedforward is Correct
  • Anticipates disturbances
  • Reduces deviation in PV
  • Improves overall control performance
:cross_mark: Why other options are wrong
  • A. Feedback → Reacts after PV changes (reactive control)
  • B. Cascade → Improves response speed, but still reacts after disturbance enters
  • D. Ratio → Maintains proportional relationship, does not anticipate disturbance
:white_check_mark: Final Takeaway
:backhand_index_pointing_right: Only feedforward control predicts and compensates disturbances before they affect the process.
