When a FHP motor operates at 120 volts, the toggle switch must be located in (wired in series with) the _____________________ supply conductor to the motor.
The _____________________ return circuit conductor must have a solid (screw terminal) connection between the motor winding lead and the neutral supply busbar or terminal strip in the supply load center.
A) ungrounded; grounded
B) grounded; ungrounded
C) grounded; grounded
D) none of the answers
Answer:A
