When a single-phase AC induction motor operates at the lower phase-to-ground voltage of 115 volts and the motor field leads are number-identified, the ___ circuit conductor should be connected to motor terminal T1
When a single-phase AC induction motor operates at the lower phase-to-ground voltage of 115 volts and the motor field leads are number-identified, the _____________________ circuit conductor should be connected to motor terminal T1.
The ____________________ circuit conductor should be connected to motor terminal T2.
A) ungrounded; ungrounded
B) grounded; ungrounded
C) ungrounded; grounded
D) grounded; grounded
Answer:C
