When a single phase induction motor is excited with single phase ac voltage, the ___
When a single phase induction motor is excited with single phase ac voltage, the magnetic field set up is equivalent to
A. two fields, rotating in opposite directions with different speeds
B. two fields, rotating at synchronous speed in opposite directions.
C. two fields, rotating at synchronous speed
D. two fields, rotating in the same direction but at different speeds.
