When approximate values for resistance, capacitance, or inductance to be measured by a bridge are unknown, which, if any, of the following actions should you take?
A. Connect two bridges in parallel to make the measurement
B. Assign a temporary value to the component and set up the bridge accordingly
C. Place an adjustable shunt across the meter terminals
D. None of the above
