When comparing resistance readings of an enhancement type of MOSFET to those of a depletion/enhancement type of MOSFET, which, if any, of the following differences should you notice?
A. The resistance between the substrate and the gate of the enhancement type should be less than 15 ohms
B. The measurement between the drain and source of the enhancement type should read infinite regardless of meter lead polarity
C. The resistances between the gate and the drain and between the gate and the source of the enhancement type should be noticeably higher
D. None of the above
