When taking forward and reverse resistance readings between ___
When taking forward and reverse resistance readings between a transistor’s emitter and collector, what type of reading should you get?
A. Both the forward and reverse readings should be nearly the same
B. A short in both the forward and reverse directions
C. Less than 15 ohms when measuring in the forward direction and infinite in the reverse direction
D. Less than 15 ohms in the reverse direction and infinite in the forward direction
