When using an oscilloscope to measure a high voltage, you should use ___
When using an oscilloscope to measure a high voltage, you should use which of the following procedures?
A. Use the logic probe instead of the normal probe
B. Use the high voltage probe instead of the normal probe
C. Use two oscilloscopes connected in series
D. Place a 10-ohm shunt across the vertical input of the oscilloscope
