Which device serves as a temperature reference during RTD calibration?
A. Pressure gauge
B. Reference thermometer
C. Voltmeter
D. Ammeter
Explanation:
A Reference Thermometer is used as the temperature standard during RTD calibration. It provides a highly accurate temperature measurement against which the RTD’s reading can be compared.
During calibration:
  1. The RTD and reference thermometer are placed in the same temperature source (such as a temperature bath or dry block calibrator).
  2. The temperature is stabilized.
  3. The RTD reading is compared with the reference thermometer reading.
  4. Any error or deviation is recorded and corrected if necessary.
Why a Reference Thermometer is Used
:white_check_mark: High accuracy
:white_check_mark: Traceable calibration standards
:white_check_mark: Reliable temperature reference
:white_check_mark: Used in calibration laboratories and industries
Pressure Gauge
  • Measures pressure, not temperature.
Voltmeter
  • Measures electrical voltage.
  • Cannot serve as a temperature standard.
Ammeter
  • Measures electrical current.
  • Not used as a temperature reference.
Common RTD Calibration Setup
  • Temperature Bath or Dry Block Calibrator
  • Reference Thermometer
  • RTD Under Test
  • Temperature Calibrator or Indicator
Because calibration requires a highly accurate temperature standard, the Reference Thermometer is the device that serves as the temperature reference.
Therefore, Option B (Reference Thermometer) is the correct answer. :white_check_mark:
