Which metal is most commonly used in RTD?
Which metal is most commonly used in RTDs?
A. Zinc
B. Aluminum
C. Platinum
D. Tin
Explanation:
Platinum is the most commonly used metal in industrial RTDs (Resistance Temperature Detectors) because of its excellent accuracy, stability, repeatability, and corrosion resistance.
The most popular RTDs are:
  • Pt100 → 100 Ω at 0°C
  • Pt1000 → 1000 Ω at 0°C
The “Pt” in Pt100 and Pt1000 stands for Platinum.
Why Platinum is Preferred
:white_check_mark: High accuracy
:white_check_mark: Excellent long-term stability
:white_check_mark: Wide operating temperature range
:white_check_mark: Good linearity
:white_check_mark: Resistant to oxidation and corrosion
:white_check_mark: Internationally standardized (IEC 60751)
Typical Platinum RTD Values
  • 0°C → 100.0 Ω
  • 100°C → 138.5 Ω
  • 200°C → 175.9 Ω
Zinc
  • Not commonly used for RTD sensing elements.
Aluminum
  • Poor long-term stability compared to platinum.
Tin
  • Unsuitable for precision temperature measurement.
Because platinum provides the best combination of accuracy, stability, and reliability, Option C (Platinum) is the correct answer. :white_check_mark:
