Which of the following condition is true for determining overflow condition in 2’s complement?
complement?
A. When adding two positive numbers gives a negative result or when two
negatives give a positive result.
B. If sign bit (MSB) of result and sign bit of two operands are of different signs.
C. The ‘1’ in the MSB position indicates a negative number after adding two
positive numbers.
D. All of the above
