Which of the following statements associated with a 3-wire generator are correct?
A. It is an ordinary dc generator with a special provision for connecting the neutral wire to the armature winding.
B. It is somewhat more expensive than the standard one.
C. For operating 3-wire compound generators in parallel it is necessary that two equalizer connections are used to connect all series fields in parallel.
D. There are two series fields on each 3-wire compound generator.
E. all of the above
Answer: E
