Which of the following statements correctly describes the ___
Which of the following statements correctly describes the accuracy and use of a reactance-type capacitance meter?
A. It gives approximate values and is usually portable
B. It gives approximate values and is used in calibration laboratories only
C. It is very accurate and is usually portable
D. It is very accurate and is used to measure capacitors that have a high power factor
