Which one of the following generator conditions is most likely to result in equipment damage from high current flow ___
Which one of the following generator conditions is most likely to result in equipment damage from high current flow?
A. Tripping the output breaker under full-load conditions.
B. Tripping the generator prime mover under full-load conditions.
C. Closing the output breaker onto a bus that has a short-circuit fault.
D. Closing the output breaker onto a bus that has an open-circuit fault.
