Which one of the following modifications would decrease the pumps available net positive suction head ___
Refer to the drawing of a centrifugal pump taking suction from a reservoir (see figure below).
centrifugal pump taking suction from a reservoir-PG-56
The pump is located on shore, with the eye of the pump 4 feet higher than the reservoir water level.
The pumps suction line extends 4 feet below the surface of the reservoir.
Which one of the following modifications would decrease the pumps available net positive suction head?
(Assume the reservoir is at a uniform temperature and ignore any changes in suction line head loss due to friction.)
A. Raise the pump and suction line by 2 feet.
B. Lower the pump and suction line by 2 feet.
C. Lengthen the suction line to take a suction from 2 feet deeper.
D. Shorten the suction line to take a suction from 2 feet shallower.
