Which PID term directly influences the speed of initial response?
Question:
Options:
A) Proportional
B) Integral
C) Derivative
D) Gain
:white_check_mark: Correct Answer: A) Proportional
The Proportional (P) term directly affects how fast the controller reacts when an error first appears.
Mathematically:
Pout = Kp x e(t)
When a disturbance or setpoint change occurs:
  • Proportional action responds immediately
  • Higher ( Kp ) β†’ Larger output change
  • Larger output β†’ Faster movement of PV toward SP
This reduces rise time (initial response speed).
:cross_mark: Why Others Are Incorrect
B) Integral
Acts slowly because it accumulates error over time. It improves steady-state accuracy, not initial speed.
C) Derivative
Improves damping and reduces overshoot but does not primarily determine initial response speed.
D) Gain
β€œGain” alone is not a PID term. Proportional gain (Kp) influences speed, but the control mode responsible is Proportional.
:fire: Practical Insight
  • If the loop is sluggish β†’ Increase Kp slightly
  • If the loop oscillates β†’ Kp may be too high
Quick Summary:
  • P β†’ Speed
  • I β†’ Accuracy
  • D β†’ Stability
