Which RTD type is most common in process industries?
A. Pt1000
B. Pt250
C. Pt500
D. Pt100
Explanation:
The Pt100 is the most widely used RTD type in process industries due to its excellent balance of accuracy, stability, availability, and compatibility with industrial instruments.
The term Pt100 means:
  • Pt = Platinum sensing element
  • 100 = 100 Ω resistance at 0°C
Comparison of Common RTD Types
Pt100
  • 100 Ω at 0°C
  • Most common industrial RTD
  • Widely supported by PLCs, DCSs, transmitters, and temperature controllers
  • Excellent accuracy and stability
Pt1000
  • 1000 Ω at 0°C
  • Higher sensitivity than Pt100
  • Often used in HVAC and building automation applications
Pt500
  • 500 Ω at 0°C
  • Less common than Pt100 and Pt1000
Pt250
  • Rarely used in industrial applications
Why Pt100 is Preferred
:white_check_mark: Internationally standardized under IEC 60751
:white_check_mark: Widely available from all major manufacturers
:white_check_mark: Suitable for long-distance industrial measurements
:white_check_mark: Compatible with most temperature transmitters and control systems
:white_check_mark: Proven reliability in process industries
Because of its widespread adoption and industry acceptance, Pt100 is the most common RTD type used in process industries.
Therefore, Option D (Pt100) is the correct answer. :white_check_mark:
