Which thermowell material is commonly used in industry?
A. Plastic
B. Stainless steel
C. Rubber
D. Iron
Explanation:
Stainless steel is the most commonly used thermowell material in industrial applications because it provides excellent mechanical strength, corrosion resistance, and temperature resistance.
Thermowells are used to protect temperature sensors such as RTDs and thermocouples from harsh process conditions while allowing accurate temperature measurement.
Advantages of Stainless Steel Thermowells
Excellent corrosion resistance
High mechanical strength
Good temperature resistance
Suitable for high-pressure applications
Long service life
Compatible with many industrial fluids
Common Stainless Steel Grades
- SS304
- SS316
- SS316L
Among these, SS316/SS316L are widely used in chemical plants, oil & gas facilities, power plants, and process industries due to their superior corrosion resistance.
Plastic
- Limited temperature and pressure capability.
Rubber
- Not suitable for thermowell construction.
Iron
- Prone to corrosion and rarely used for modern industrial thermowells.
Because of its durability, corrosion resistance, and suitability for demanding process environments, Stainless Steel is the most commonly used thermowell material in industry.
Therefore, Option B (Stainless Steel) is the correct answer. ![]()
