Why is on-off control not suitable for continuous process control?
Question:
Options:
A) Minimizes dead time
B) Causes continuous cycling
C) Eliminates steady error
D) Provides linear output
:white_check_mark: Correct Answer: B) Causes continuous cycling
On-off (bang-bang) control operates in only two states:
  • Fully ON
  • Fully OFF
When the process variable crosses the setpoint:
  • Output switches abruptly
  • The process overshoots
  • Output switches again
This results in continuous cycling around the setpoint rather than smooth regulation.
For continuous processes (temperature, pressure, flow):
  • Smooth modulation is required
  • Actuators should not continuously switch
  • Stable steady control is preferred
PID control provides gradual, proportional adjustment instead of abrupt switching.
:repeat_button: Practical Issues with On-Off Control
  • Oscillations around SP
  • Equipment wear (valves, relays)
  • Poor accuracy
  • Large temperature or pressure swings
A) Minimizes dead time → On-off does not affect process dead time.
C) Eliminates steady error → It oscillates around SP, not eliminate error smoothly.
D) Provides linear output → On-off output is binary, not linear.
