1oo3 Logic Explained
:police_car_light: What is 1oo3 #Voting #Logic in Safety Systems?
In critical industrial processes, fast protection is sometimes more important than avoiding nuisance trips.
That’s where #1oo3 voting logic is used.
1oo3 Logic
Let’s understand it simply. :backhand_index_pointing_down:
:small_blue_diamond: What does 1oo3 mean?
:right_arrow: 1oo3 = One out of Three
The safety system will activate a trip if ANY one sensor detects a dangerous condition.
:gear: How it works
Three sensors monitor the same process variable.
• Sensor 1
• Sensor 2
• Sensor 3
If just one sensor crosses the trip limit, the system immediately activates the shutdown.
:police_car_light: 1 sensor detects danger → Trip occurs
:brain: Why 1oo3 logic is used
This logic prioritizes maximum safety response.
:white_check_mark: Fastest trip response
Only one signal is needed to trigger protection.
:white_check_mark: High safety sensitivity
Dangerous conditions are detected immediately.
:warning: Higher chance of nuisance trips
A faulty sensor can trigger a shutdown.
:bar_chart: Example scenario
High Temperature Trip = 250°C
Sensor…Reading
T-1…255°C
T-2…245°C
T-3…248°C
:right_arrow: One sensor detects high temperature
:police_car_light: System trips immediately
:high_voltage: Where 1oo3 logic is commonly used
• Gas detection systems
• Fire detection systems
• Critical emergency shutdown triggers
• Highly hazardous process protection
:bullseye: Key idea
:one: Only one sensor needed to trip
:two: Fastest response to dangerous conditions
:three: Higher probability of false trips
:light_bulb: In simple words
1oo3 logic prioritizes safety over availability — the system trips even if only one sensor detects danger.
#ProcessSafety #FunctionalSafety #Instrumentation #SIS Automation #IndustrialSafety #ControlSystems
