A cumulatively compounded dc motor delivers rated load power at ___
A cumulatively compounded dc motor delivers rated load power at rated speed.
If the series field is short-circuited, then
A. both armature current Ia and speed ωm increase
B. Ia remains constant but ωm increase
C. Ia increases and ωm decreases
D. both decrease
If the series field of a cumulatively compounded DC motor is short-circuited, it means that the series field current becomes zero. In this case, the motor essentially becomes a shunt motor.
In a shunt motor, the speed is inversely proportional to the armature current. When the series field is short-circuited, the armature current remains constant, but the speed of the motor increases. This is because the absence of the series field current reduces the magnetic field strength, resulting in a higher speed of rotation.
Therefore, the correct answer is B. The armature current (Ia) remains constant, but the speed (ωm) increases when the series field is short-circuited in a cumulatively compounded DC motor.
