A leak develops in the high-pressure side of a flow detector. What effect does the leak have on the affected flow indication ___
A leak develops in the high-pressure side of a flow detector. What effect does the leak have on the affected flow indication?
A. The measured ΔP will decrease, causing indicated flow to decrease.
B. The measured ΔP will decrease, causing indicated flow to increase.
C. The measured ΔP will increase, causing indicated flow to decrease.
D. The measured ΔP will increase, causing indicated flow to increase.
Answer:A
