A main generator is connected to an infinite power grid with the following generator output parameters:
22 KV
60 Hertz
975 MW
200 MVAR (out)
Main generator stator winding temperature is abnormally high.
Which one of the following contains a combination of manual adjustments to the main generator speed control and voltage regulator setpoints such that each adjustment will reduce the main generator stator winding temperature?
(Assume power factor remains less than 1.0.)
