A steam flow measuring instrument uses density compensation and square root extraction to convert the differential pressure across the flow element to flow rate in lbm/hr.
The purpose of density compensation in this flow measuring instrument is to convert __________ into __________.
A. volumetric flow rate; mass flow rate
B. steam pressure; mass flow rate
C. steam velocity; volumetric flow rate
D. differential pressure; volumetric flow rate
Answer:A
