A synchro is zeroed by the use of a synchro tester ___
A synchro is zeroed by the use of a synchro tester.
After it is zeroed, the S1 and S3 leads are shorted together, and the synchro tester dial moves.
What does this indicate?
A. The supply voltage is too high
B. The synchro is not zeroed correctly
C. The supply voltage is too low
D. The synchro is zeroed correctly
