- ADMAG stands for
- Ideal for measuring flow of most of conductive liquid.
- Posses no moving parts, no pressure loss and requires minimal maintenance.
- Highly accurate, shorter pipe length, bidirectional flow measurement and doesn’t require straight pipe lenghts.
Principle:
E = B * V * D
B is magnetic flux density
V is fluid viscosity
D is pipe diameter
- ADMAG series works with dual frequency excitation method.
- Dual frequency excitation provides excellent immunity to noise & stability.
- Spring loaded electrode material is leak free & chemically resistive.
- Reinforced with metal plate provides strength in vacuum applications.
- Liner material made up of ceramics, polyurethane rubber, natural soft rubber.
- Grounding rings provide suppression against electrical interference.
- Supports HART protocol only.
ADMAG AWX is simple, robust & large: 500 to 1800m(20 to 72 in)
Applications:
- Paperppulp
- Food beverage
- Mining
- Waste water(seawage) & chemical industries.
