An air-operated isolation valve requires 3,600 pounds-force applied to the top of the actuator diaphragm to open.
The actuator diaphragm has a diameter of 9 inches and the valve stem travels 3 inches from fully open to fully closed.
If control air pressure to the valve actuator begins to increase from 0 psig, which one of the following is the approximate air pressure at which the valve will begin to open?
A. 14 psig
B. 57 psig
C. 81 psig
D. 127 psig
