Architecture of Safety PLC (1oo1, 1oo2, 2oo3)
:shield: Safety PLC Architectures Explained — 1oo1 vs 1oo2 vs 2oo3
In Safety PLC systems, architecture defines:
:backhand_index_pointing_right: How reliable the protection system is during failures
The most common architectures are :backhand_index_pointing_down:
:green_circle: 1oo1 Architecture (One out of One)
:right_arrow: Single sensor / single channel
:right_arrow: One signal is enough for action
:high_voltage: Simple design
:high_voltage: Low cost
:warning: No redundancy
:backhand_index_pointing_right: If the only device fails → Protection may be lost
:yellow_circle: 1oo2 Architecture (One out of Two)
:right_arrow: Two channels working together
:right_arrow: One healthy channel can maintain protection
:high_voltage: Better reliability
:high_voltage: Fault tolerance available
:warning: More hardware & complexity
:backhand_index_pointing_right: Common in SIL 2 systems
:red_circle: 2oo3 Architecture (Two out of Three)
:right_arrow: Three channels with majority voting
:right_arrow: Any 2 signals out of 3 decide action
:high_voltage: High reliability
:high_voltage: Can tolerate one faulty device
:high_voltage: Reduces nuisance trips
:backhand_index_pointing_right: Widely used in SIL 3 applications
:brain: Simple comparison
:green_circle: 1oo1 → Simple but no backup
:yellow_circle: 1oo2 → Redundancy available
:red_circle: 2oo3 → Best balance of safety & availability
:factory: Where used
:green_circle: 1oo1 → Basic protection systems
:yellow_circle: 1oo2 → Medium critical safety loops
:red_circle: 2oo3 → ESD, HIPPS, turbine protection
SIS Videos
:bullseye: Key takeaway
:one: More redundancy = Higher reliability
:two: Better voting logic = Better fault tolerance
:three: Architecture selected based on required SIL
:backhand_index_pointing_right: 1oo1 = One chance
:backhand_index_pointing_right: 1oo2 = Backup available
:backhand_index_pointing_right: 2oo3 = Majority decides safely
#SafetyPLC #FunctionalSafety #SIS Automation #Instrumentation #ProcessSafety #ControlSystems #Engineering #IEC61511 #IndustrialAutomation :rocket:
