Quick Answer: What Is the Best ATG System for Fuel Storage?
A magnetostrictive Automatic Tank Gauging (ATG) system is a suitable solution for fuel storage facilities requiring high-accuracy fuel level measurement, continuous bottom water detection, and automated inventory monitoring.
A dual-float magnetostrictive probe can measure the fuel surface and the fuel-water interface simultaneously. Combined with an ATG console or remote monitoring gateway, it enables operators to monitor tank inventory, track water accumulation, record temperature, and manage multiple storage tanks from a central location.
This technology is particularly suitable for gas stations, underground storage tanks (USTs), aboveground storage tanks (ASTs), fuel depots, and industrial fuel storage facilities.
The right ATG configuration depends on tank dimensions, fuel type, measurement accuracy, water detection requirements, hazardous area classification, and communication protocols.
1. What Is an Automatic Tank Gauging (ATG) System?
An Automatic Tank Gauging (ATG) system is an integrated solution that automatically measures and monitors liquid levels inside underground storage tanks (USTs) and aboveground storage tanks (ASTs).
Unlike manual dipping with a measuring stick, an ATG system provides continuous electronic measurement and data transmission.
A magnetostrictive ATG system can monitor several important parameters:
Fuel level: Measures the height of fuel inside the tank.
Bottom water level: Detects and measures water accumulation at the bottom of the tank.
Fuel temperature: Provides temperature data for inventory calculations and compensation.
Fuel inventory: Converts measured levels into estimated fuel volumes using tank calibration data.
Abnormal level changes: Helps identify unusual fuel consumption, potential losses, or unexpected changes.
1.1 Why Is ATG Important for Fuel Storage?
Fuel storage operators face several challenges:
Manual measurement is time-consuming and subject to human error.
Water accumulation can contaminate fuel and damage engines or dispensing equipment.
Temperature changes affect fuel volume and inventory reconciliation.
Unexplained fuel losses may indicate leakage, unauthorized withdrawal, or measurement errors.
Multiple tanks and remote locations make centralized monitoring difficult.
An ATG system helps address these challenges through automated measurement, alarms, inventory records, and centralized monitoring.
However, ordinary ATG inventory monitoring should not automatically be considered a certified automatic leak detection system. Regulatory compliance depends on the complete system and applicable local requirements.
2. How Does a Magnetostrictive ATG Probe Work?
Magnetostrictive technology is widely used in high-accuracy fuel tank gauging because it provides precise liquid-level measurement and can detect the fuel-water interface through a suitable dual-float configuration.
2.1 Magnetostrictive Measurement Principle
A magnetostrictive probe typically consists of a rigid measuring stem containing a waveguide wire and an electronic measurement unit.
The measurement process works as follows:
The electronic unit sends a short current pulse through the waveguide.
The current generates a magnetic field around the wire.
The magnetic field interacts with the permanent magnet inside the float.
This interaction generates a torsional mechanical pulse through the magnetostrictive effect.
The torsional pulse travels along the waveguide to the detector.
The electronics calculate the float position by measuring the pulse travel time.
Magnetostrictive technology is suitable for accurate fuel-level measurement across different tank applications, provided the probe and float configuration are correctly selected.
2.2 Dual-Float Technology for Fuel and Water Detection
One of the major advantages of a dual-float magnetostrictive ATG probe is its ability to measure both the fuel surface and the water interface. A typical probe uses two independent floats:
Product Float: The upper float follows the fuel surface and provides the total fuel-level measurement.
Water Interface Float: The lower float is designed with suitable buoyancy to sink through the fuel and float at the boundary between the fuel and the denser water layer.
By measuring the positions of both floats, the system can determine:
Total fuel level.
Fuel-water interface height.
Bottom water accumulation.
Actual fuel height above the water layer.
Float density and buoyancy must be selected according to the actual fuel density and operating conditions. Gasoline, diesel, and biodiesel blends can have different density ranges, so float compatibility should be confirmed before ordering.
2.3 Temperature Measurement for Fuel Inventory Management
Some magnetostrictive ATG probes also incorporate temperature measurement. Temperature data helps operators understand changes in fuel volume caused by temperature fluctuations.
When combined with suitable tank calibration tables and volume correction algorithms, the monitoring system can calculate temperature-compensated fuel volume at a defined reference temperature.
This is particularly useful for commercial fuel storage, fuel distribution depots, and inventory reconciliation.
3. Why Choose Magnetostrictive Technology for Fuel Tank Gauging?
For fuel storage applications requiring accurate inventory measurement and continuous water-interface monitoring, magnetostrictive technology offers several important advantages.
3.1 High-Accuracy Fuel Level Measurement
Magnetostrictive probes provide precise position measurement through electronic time-of-flight calculation. This supports accurate tank inventory monitoring and helps reduce errors associated with manual dipping.
The required accuracy should be selected according to tank capacity, inventory management requirements, and the applicable project specifications.
3.2 Continuous Fuel-Water Interface Detection
Water can enter fuel storage tanks through condensation, leakage, or contaminated fuel deliveries.
Even a relatively small water layer can create operational problems, particularly in diesel storage and backup generator systems.
A dual-float magnetostrictive probe can continuously monitor the fuel-water interface rather than simply indicating whether water is present.
Operators can use this information to schedule water removal and investigate potential contamination.
3.3 Temperature Monitoring and Inventory Compensation
Fuel volume changes with temperature.
By integrating temperature measurements with suitable tank calibration data and correction algorithms, an ATG system can support more consistent inventory calculations.
This is especially valuable for fuel depots handling large storage volumes.
3.4 Continuous Automated Monitoring
Once installed and configured, a magnetostrictive ATG system can collect tank measurements automatically.
Operators can access information through an ATG console, industrial control system, or compatible cloud platform.
This reduces dependence on manual inspections and improves operational visibility.
3.5 Multi-Tank Monitoring
Multiple magnetostrictive probes can be connected to a compatible monitoring system.
A centralized ATG console can collect data from several tanks, allowing operators to review fuel inventory, water levels, and temperature information from one interface.
This is useful for gas stations, commercial fuel depots, and industrial facilities managing multiple storage tanks.
4. How to Build a Magnetostrictive ATG System for Multiple Fuel Tanks?
A complete ATG system typically consists of four main components:
Magnetostrictive ATG probes.
An ATG console or communication gateway.
A communication network.
A monitoring platform or control system.
The system architecture depends on tank quantity, installation distance, available power, and integration requirements.
4.1 RS485 Modbus Networking for Gas Stations
A gas station may operate four to eight underground tanks containing different fuel products. A compatible magnetostrictive probe can connect to an ATG console through an RS485 Modbus RTU communication bus.
A typical architecture is:
Magnetostrictive Probes → RS485 Modbus RTU → ATG Console → Monitoring Software
The system can collect fuel level, water interface, and temperature data from multiple tanks.
Before installation, confirm:
Modbus device addresses and register mapping.
Cable distance, bus topology, and termination.
Power supply and intrinsic safety requirements.
Compatibility with the ATG console or forecourt controller.
Supported probe quantity and communication capacity.
4.2 4G and LoRaWAN for Distributed Fuel Storage
For logistics hubs, industrial parks, and remote generator installations, running communication cables back to a central control room may be expensive.
A wireless communication architecture can provide centralized monitoring across distributed sites.
A typical configuration is:
Magnetostrictive ATG Probe → Compatible Data Acquisition Unit → 4G / LoRaWAN Gateway → Cloud Platform → User Dashboard
Depending on the selected equipment, operators can access:
Real-time fuel inventory.
Bottom water-level information.
Historical measurement trends.
High- and low-level alarms.
Abnormal inventory change notifications.
Multi-site tank monitoring reports.
The selected communication device must support the probe’s electrical interface and data protocol. Battery-powered installations also require evaluation of reporting frequency, power consumption, and battery capacity.
4.3 Integration with SCADA and Cloud Platforms
Fuel monitoring data may need to be transferred to an existing fleet management platform, SCADA system, or customer-built cloud application.
Common communication options include:
RS485 Modbus RTU for local controllers.
4–20 mA or HART where supported by the selected configuration.
MQTT over cellular networks for cloud telemetry.
LoRaWAN or compatible low-power wireless networks.
For platforms, confirm the required protocol, gateway compatibility, register mapping, and integration method before deployment.
Standard protocol support does not automatically mean that a specific platform connection has already been validated.
5. Magnetostrictive ATG Applications in Fuel Storage
Retail Gas Stations with Multiple Underground Tanks
Fuel Depots and Industrial Storage Facilities
Distributed Diesel Tanks for Fleets and Backup Generators
Marine Fuel Storage
6. How to Select the Right Magnetostrictive ATG Probe: 5 Engineering Considerations
Selecting an ATG probe requires more than confirming the required measuring range. The probe, materials, electrical interface, and communication system must all match the application.
Step 1: Confirm Tank Dimensions and Installation Conditions
Provide the following information:
Tank height and diameter.
Tank shape and capacity.
Underground or aboveground installation.
Installation port size and mounting method.
Required probe length.
Available clearance inside the tank.
The measuring probe must be compatible with the actual tank dimensions and installation arrangement.
Step 2: Confirm Fuel Type and Compatibility
Identify whether the tank stores gasoline, diesel, biodiesel, or another fuel. The fuel density directly affects float buoyancy and interface measurement.
Confirm:
Expected fuel density range.
Fuel compatibility of wetted materials.
Step 3: Define Accuracy and Water Detection Requirements
Determine whether the project requires:
Continuous measurement of both fuel level and water interface.
Temperature measurement.
Fuel volume.
Also specify the required measurement accuracy and resolution.
Step 4: Verify Hazardous Area Classification and Certifications
Fuel storage environments may contain flammable vapors. Confirm the hazardous area classification and the required ATEX, IECEx, or other local approvals.
Check the complete installation configuration, including the probe, associated apparatus, barriers, wiring, and installation conditions.
Do not assume that a probe certification automatically covers the entire ATG installation.
Step 5: Select Communication and Integration Methods
Choose the communication method according to the receiving system:
· RS485 Modbus RTU for ATG consoles and local controllers.
· 4–20 mA or HART where supported by the selected model.
· 4G for remote monitoring.
· LoRaWAN for compatible low-power wireless applications.
For multi-tank projects, confirm the maximum device quantity, communication distance, network architecture, and third-party platform requirements.
7. Frequently Asked Questions About Magnetostrictive ATG Systems
Q1. Can a magnetostrictive ATG system monitor multiple fuel tanks?
Yes. Multiple compatible probes can connect to an ATG console or data acquisition system through a supported communication architecture.
Q2. Can an ATG system calculate the actual fuel volume in liters?
Yes. The monitoring system can convert measured fuel height into volume using the tank’s calibration table or strapping chart.For temperature-compensated volume, suitable temperature measurements and the required correction algorithms must also be available.
Q3. Can magnetostrictive ATG probes connect to SCADA or cloud platforms?
Yes, provided the selected probe, controller, or gateway supports a compatible communication protocol.
Integration may use RS485 Modbus RTU, 4–20 mA, HART, or a wireless gateway, depending on the equipment configuration.
Q4. Are magnetostrictive ATG probes suitable for underground fuel tanks?
Yes. They are commonly used in underground fuel storage applications.
Q5. Is a magnetostrictive ATG probe suitable for marine fuel tanks?
It may be suitable, depending on tank geometry, fuel movement, vibration, installation conditions, and applicable marine certification requirements. The complete installation should be evaluated before selecting the probe.
8. Get a Magnetostrictive ATG Solution for Your Fuel Storage Project
Selecting the right ATG system requires more than choosing a level probe.
Tank dimensions, fuel characteristics, float configuration, water detection requirements, hazardous-area classification, and communication architecture all affect the final solution.
HOLYKELL provides magnetostrictive fuel-level measurement and remote monitoring solutions for gas stations, fuel depots, industrial facilities, and other fuel storage applications.
Step 1: Submit Your Application Parameters
To help our engineering team recommend a suitable magnetostrictive ATG probe, please provide:
Tank type
Tank dimensions
Fuel type
Measurement range
Measurement accuracy
Required accuracy and resolution
Step 2: Engineering Selection and System Configuration
Our engineering team can review your application requirements and recommend a suitable magnetostrictive probe, communication method, and monitoring architecture.
For multi-tank projects, we can also discuss ATG console compatibility, data acquisition, and remote monitoring integration.
Step 3: Sample Testing and Solution Consultation
Before full deployment, discuss sample testing, protocol integration, wiring requirements, float compatibility, and installation conditions with our technical team.
Ready to Upgrade Your Fuel Tank Monitoring System?
