Because the start winding is purposely made more resistive than inductive, and because the starting winding current is out of phase with both the ___
Because the start winding is purposely made more resistive than inductive, and because the starting winding current is out of phase with both the supply-circuit current and the run or main winding current in a single-phase AC induction motor, it will become the _______________ ___________ of not only the supply circuit but of the current in the run winding once the motor is running.
The smaller gauge wire will quickly become _______________.
The overload current will quickly _______________ the start winding and cause the winding to ___________ ___________ if it is not disconnected from the circuit once the motor is running.
A) overheat; melt open; connected load; overloaded
B) connected load; overloaded; overheat; melt open
C) overloaded; connected load; overheat; melt open
D) none of the answers
Answer:B
