Common mistakes in SIL calculation
:stop_sign: Common Mistakes in SIL Calculation — Engineers Must Avoid
SIL calculation is not just numbers…
A small mistake can lead to under-design or over-design :backhand_index_pointing_down:
:gear: Why it matters
:backhand_index_pointing_right: Wrong SIL =
:cross_mark: Unsafe system
:cross_mark: Unnecessary cost
:cross_mark: Compliance issues
:police_car_light: Common mistakes in SIL calculation
:red_circle: Using wrong failure data
:right_arrow: Outdated or unrealistic failure rates
:warning: Leads to incorrect PFD values
:red_circle: Ignoring common cause failures (CCF)
:right_arrow: Assuming redundant devices are fully independent
:warning: Real systems often share environment, power, or design
:red_circle: Incorrect proof test interval
:right_arrow: Using unrealistic testing frequency
:warning: Directly impacts SIL calculation
:red_circle: Overestimating diagnostic coverage
:right_arrow: Assuming higher fault detection than actual
:warning: Gives false confidence in system reliability
:red_circle: Mixing SIL verification and validation
:right_arrow: Confusing calculation with real testing
:warning: Both are required separately
:red_circle: Not considering real process conditions
:right_arrow: Lab data ≠ Field conditions
:warning: Temperature, vibration, environment affect reliability
:red_circle: Assuming redundancy = higher SIL automatically
:right_arrow: Wrong architecture or poor design reduces effectiveness
:warning: Design matters more than quantity
:red_circle: Ignoring human factors
:right_arrow: Operator response assumed perfect
:warning: Human error must be considered
:bullseye: Key takeaway
:one: Use accurate and validated data
:two: Consider real-world conditions
:three: Follow standards properly
:four: Validate with actual testing
:backhand_index_pointing_right: SIL calculation is not just math…
:backhand_index_pointing_right: It’s engineering + data + real conditions
:warning: Don’t just calculate SIL… engineer it correctly
:backhand_index_pointing_right::backhand_index_pointing_right: WATCH VIDEO:
#FunctionalSafety #SIL #ProcessSafety #Instrumentation Automation #ControlSystems #Engineering #IEC61511 #SafetyEngineering #IndustrialSafety :rocket:
