__________ current(s) (is) are high-magnitude fault overcurrent(s) that can destroy circuit conductors or wiring contained within the electrical distribution or utilization equipment if not kept in check.
The contact point of the fault overcurrent in effect places a low point-contact resistance in parallel with the impedance of the connected load(s).
A) Short circuit
B) Ground fault
C) Both Ground fault & Short circuit
D) Overload
Answer:C
