Difference between SIS anda BPCS
:gear: SIS vs BPCS — Don’t Confuse Control with Safety
In industrial automation, both systems look similar…
But their purpose is completely different :backhand_index_pointing_down:
:green_circle: BPCS (Basic Process Control System)
:right_arrow: Controls the normal operation of the plant
:high_voltage: Maintains temperature, pressure, flow
:high_voltage: Runs continuous process loops
:high_voltage: Optimizes performance & efficiency
:backhand_index_pointing_right: Goal: Keep the process running
:red_circle: SIS (Safety Instrumented System)
:right_arrow: Protects the plant during abnormal conditions
:high_voltage: Detects dangerous situations
:high_voltage: Initiates automatic shutdown (trip)
:high_voltage: Prevents accidents & hazards
:backhand_index_pointing_right: Goal: Keep the plant safe
:brain: Key Differences
:small_blue_diamond: BPCS → Continuous control
:small_blue_diamond: SIS → Emergency action
:small_blue_diamond: BPCS → Works all the time
:small_blue_diamond: SIS → Acts only when needed
:small_blue_diamond: BPCS → No SIL requirement
:small_blue_diamond: SIS → Designed with SIL levels
:small_blue_diamond: BPCS → Failure → Process upset
:small_blue_diamond: SIS → Failure → Safety risk
:factory: Example
:fire: High Temperature Condition:
:backhand_index_pointing_right: BPCS → Adjusts control valve to reduce temperature
:backhand_index_pointing_right: SIS → If limit exceeded → Trips the system
:backhand_index_pointing_down::backhand_index_pointing_down: WATCH VIDEO:
:bullseye: Simple understanding
:backhand_index_pointing_right: BPCS = Control the process
:backhand_index_pointing_right: SIS = Protect the process
:warning: Important
:cross_mark: Never mix SIS and BPCS logic
:white_check_mark: Keep them independent for safety integrity
:light_bulb: Both are essential — one runs the plant, the other saves it.
#SIS #BPCS #ProcessSafety #Instrumentation Automation #ControlSystems #IndustrialAutomation #Engineering #IEC61511 #SafetyEngineering :rocket:
