Emf induced in a coil rotating in a uniform magnetic field will be ___
Emf induced in a coil rotating in a uniform magnetic field will be maximum when the
A. flux linking with the coil is maximum.
B. rate of change of flux linkage is minimum.
C. rate of change of flux linkage is maximum.
D. rate of cutting flux by coil sides is minimum.
