ESD system - inhibit signals
:police_car_light::locked: ESD SYSTEM – INHIBIT SIGNALS: When a Trip Condition Is Temporarily Prevented! :gear::factory:
In an ESD (Emergency Shutdown) system, an inhibit signal is used to prevent a specified input, condition, or logic action from producing its normal shutdown response under defined circumstances.
:warning: An inhibit does not make the hazardous condition disappear—it only changes how the ESD logic responds to it.
:small_blue_diamond: Simple Example
Consider:
High-High Pressure → ESD Logic → Shutdown Valve
Normally:
:police_car_light: HH Pressure detected
:down_arrow:
:brain: ESD logic
:down_arrow:
:locked: Shutdown valve closes
If an approved inhibit is active:
:down_arrow:
:locked: Inhibit active
:down_arrow:
:cross_mark: Specified ESD action is prevented
The exact behavior depends on the configured ESD logic.
:factory: Why Are Inhibit Signals Used?
Inhibits may be required during specific operating conditions such as:
:wrench: Maintenance
:test_tube: Testing
:rocket: Startup
:stop_sign: Shutdown
:gear: Equipment unavailable
:magnifying_glass_tilted_left: Commissioning
:factory: Defined process operating states
For example, a shutdown signal may be intentionally inhibited during startup if the process condition being monitored is expected during startup and would otherwise cause an unwanted trip.
:rocket: Startup Example
Suppose a process normally generates a low-flow condition during startup.
If the low-flow trip were active immediately:
:rocket: Start process
:down_arrow:
:chart_decreasing: Flow temporarily low
:down_arrow:
:police_car_light: Low-flow trip
:down_arrow:
:stop_sign: Process shuts down
The approved startup philosophy may therefore allow that particular trip to be inhibited during a defined startup phase.
Once normal operating conditions are established:
:unlocked: Inhibit removed
:right_arrow: The protection becomes active again.
:warning: Why Are Inhibits Dangerous?
When an inhibit is active:
:cross_mark: A safety function may not respond normally
:cross_mark: Protection may be temporarily reduced
:cross_mark: A genuine hazardous condition could go without the expected shutdown
For example:
:police_car_light: Genuine high pressure
:down_arrow:
:satellite_antenna: Trip input generated
:down_arrow:
:locked: Inhibit still active
:down_arrow:
:cross_mark: Expected shutdown does not occur
This is why inhibit management is critical.
:shield: Good Inhibit Practices
An ESD inhibit should be:
:clipboard: Authorized
:warning: Risk assessed
:bell: Clearly indicated
:busts_in_silhouette: Known to operations
:memo: Recorded
:stopwatch: Controlled for duration
:counterclockwise_arrows_button: Removed when no longer required
:white_check_mark: Verified after restoration
Where appropriate, the system may use automatic inhibit removal based on operating state or defined conditions.
:vs_button: Inhibit vs Bypass vs Force
These terms are not universally identical across all ESD/SIS platforms.
:locked: Inhibit
→ Prevents a specified signal/condition/action from participating in the defined logic.
:counterclockwise_arrows_button: Bypass
→ Temporarily prevents a specified safety function from performing its normal action.
:test_tube: Force
→ Overrides a selected signal/state with a defined value.
:backhand_index_pointing_right: Always verify the ESD vendor logic, Cause & Effect, and plant philosophy to determine exactly what an inhibit does.
:bullseye: Interview Question
What is an inhibit signal in an ESD system?
:backhand_index_pointing_right: An inhibit signal is a controlled signal used to prevent a specified ESD input, condition, or logic action from producing its normal shutdown response under defined operating or maintenance conditions.
:light_bulb: Remember:
:police_car_light: INHIBIT = The condition may still exist, but the specified ESD response is temporarily prevented.
And the most important rule:
Apply only when justified → control the risk → clearly indicate it → remove it when no longer required → verify the protection is restored. :locked::white_check_mark:
#ESD #InhibitSignal #ESDSystem #SIS #SafetyInstrumentedSystem #FunctionalSafety #ProcessSafety #IEC61511 #SafetyPLC #Instrumentation dcs #IndustrialAutomation #ControlSystems #OilAndGas #InstrumentationEngineer :police_car_light::gear::factory:
